Extract Team data (users and APC usage) via PyCelonis
  • Jan 21, 2022 3:16 PM UTC
  • 245 views
Forum|alt.badge.img+28
Hi all,
We are looking for a way to automatically obtain data from teams regarding the number of active users and APC used. Via PyCelonis would be ideally, but unfortunately we didn't find it implemented. Has somebody any idea how to do this?
Best answer by Anonymous
Hello Jan-peter,
1) Number of active users can be obtained by using option: "Enable Login history" in Team settings > Logging history. After doing that you can either use "User Adoption Views" dashboards or export the csv file, that can be analyzed with flat file upload. More info in <your-celonis-link>/help/display/CIBC/User+Adoption+Views
User activity
2) You can get the APC data usage by enabling the option:"Enable custom monitoring" in Event Collection > Monitoring. There's a ready analysis is avaiable in EMS store (needs to be adjusted due to bug mentioned in<your-celonis-link>/help/display/CIBC/Custom+Data+Pipeline+Monitoring )
bug in APC analysis
Mateusz DUdek
  • Answer
  • Jan 24, 2022 10:12 AM UTC
Hello Jan-peter,
User activity
bug in APC analysis
Mateusz DUdek
Hello Jan-peter,
User activity
bug in APC analysis
Mateusz DUdek
Thanks for your reaction Mateusz, we'll give it a try!
