Export KPI's from view or KM into documents
  • Aug 23, 2024 9:59 AM UTC
  • 159 views
bennita.dutoi12
Level 7
Good day everyone. With Analysis one could export the KPI's on an analysis into a document - is that possible for Views? I am using the old views?
Best answer by mateusz.dudek14
in short: exporting dashboard with visible KPI's is not possible with legacy views (old ones) but matrix indicates it will be available for the new views in the future. Mark as best answer if helped.
In theory maybe it could be done with using Python and Selenium in ML workbench to navigate to page and act as a regular user, but I wouldn't recommend that, unless it's kind of deal breaker: how to save opened page as pdf in Selenium (Python) - Stack Overflow
Link: https://docs.celonis.com/en/studio-feature-availability-matrix.html#UUID-d33f8a4b-cfe4-e0c2-42bc-82c2b92ebb63_section-idm4591217013932834190952697188
Mateusz Dudek
mateusz.dudek14
Level 11
Forum|alt.badge.img+10
Mateusz Dudek
