Executing Data Model Schedule from Action Flow
  • Jul 14, 2025 12:05 PM UTC
  • 209 views
A Rab
Level 3
Do you know if there is a way to execute an already exist Schedule in the Data Model from the Action flow.
I have an Action Flow that updates some fields in the source system, and I want the data jobs (extraction, transformations, and data model load) to be executed as the last step of the Action Flow, so the updates will be available in the dashboard as well.
Thanks.
julia.bauer
Level 9
Hello ​@A Rab , you can trigger a data job load with the help of the HTTP (Make a request) module within an AF. Within the screenshot is my automatic triggering of a DM load. It is also possible to trigger data jobs (see: Executing data jobs using a RESTful API).
BR
Julia Bauer
