Execute an Action Flow automatically with a Skill triggered by new data within in Action Engine
  • Jan 17, 2023 10:48 AM UTC
  • 183 views
Hello togheter,
currenty im trying to set up an action flow which is triggered by new Data in an Action Engine. I read that this can be done via a Skill. The Action Flow starts by using a custom webhook and then quering data from Celonis. For the skill, i first set up an Action Engine Sensor and secondly an "Execute Action Flow" command. Within the Action Engine i filtered the data for the data im looking.
Currently I am facing the problem that if I delete all manual inputs in the 2 commands of the skill the skill seems to trigger the action flow but the custom webhook component within the action flow doesnt receive any data. Based on this if I want to put data into the webhook it will be done manually, which is not the point of the aciton engine.
So my question is: how can i set up all these components that the skill, based on new data in an action engine, only triggers a action flow without trying to provide data to the action flow? Is that possible?
Thank you very much!
Best regards
Best answer by rio.cinco12
This is possible, calling the action flow. you don't have to pass any data on it, and it should work. But this seems to be weird for me if you don't need any data in Action Engine, try exploring the Watch Trigger instead.
imageHope this helps.
Forum|alt.badge.img+14
  • Level 8
  • Answer
  • Jan 18, 2023 7:38 AM UTC
