Does Celonis have any documentation of the algorithms they use in the process discovery and conformance checking? I need to have references for the master thesis
  • Jan 25, 2022 1:33 PM UTC
  • 81 views
Hello Johann,
I think not, but you can try asking them directly. I'm also interested in the topic from the theoretical standpoint.
Can you let me know if you will receive any answer? I hoped it would be described when comparing existing tool with open source ones in Process Mining Software by Wil van der Aalst.
Mateusz Dudek
@johann.bang  I found the post below about this topic where @joos.buijs and @janpeter.van.d  provided amazing insights.
Link: https://www.celopeers.com/s/feed/0D50700000RpOPkCAN
In other sources I've only found the information that the Directly-Follows Graph (vertical) is used in As-Is Process Visualization.
Source: https://www.processmining-software.com/tools/celonis-process-mining
