Does anybody give me a sample code to calculate through put time of workday?
  • Oct 31, 2023 9:22 AM UTC
  • 102 views
Hi all,
I'd like to calculate through put time of workday, I have a table that contains holiday. I found something workday setting but I'm not quite sure how that is work. If anybody know something like this, please give me advice.
Thanks
  • Oct 31, 2023 7:04 PM UTC
Well, you need to use a calendar and then in CALC_THROUGHPUT use the REMAP_TIMESTAMP to apply the calendar....possible a workday calendar
it is neither easy nor short to explain.
Check:
https://docs.celonis.com/en/remap_timestamps.html
https://docs.celonis.com/en/datetime-calendars.html
https://docs.celonis.com/en/workday_calendar.html
HTH
