Do we have an option to make a KPI static in a column chart?
  • Jul 24, 2022 4:57 PM UTC
  • 117 views
For eg., I want to represent the avg kpi as one of t​he kpi in a column chart and makes it static so I can basically see a straight horizontal line to the dimension to compare which dimension value has achieved the avg.
  • Jul 25, 2022 4:57 AM UTC
This can most likely be done via using a pivot table:
https://docs.celonis.com/en/pivot-table.html
Paul Velthuis
  • Jul 25, 2022 8:59 AM UTC
Hi Preethi,
You could consider using the PU_AVG function and CONSTANT() as target table.
https://docs.celonis.com/en/constant.html
Sooraj Edayattu
