Do errors propagate during extraction?
  • Mar 28, 2023 10:24 PM UTC
  • 6 replies
  • 179 views
Hi all - looking to complete an extraction and I am running into a behavior that I'm not sure if it is intended. As you can see, one SS shows successful extraction of tables labeled 800 and up. However, when an earlier tabled primed for extraction fails to run (labeled 100-800), the previously shown passing tables fail. Any ideas on what is going on here?
Forum|alt.badge.img+14
  • Level 8
  • Mar 29, 2023 9:20 AM UTC
Hi, it says on the error that Metadata has been changes, meaning the current table schema mismatch with the new data. You can resolved this by doing a FULL load or if it is not an option then you can go to extraction settings and select Option B. Included metadata changes.
  • Mar 31, 2023 7:08 PM UTC
Hi Rio,
Thanks for the quick reply. That makes sense to solve metadata issues, but my main question was to understand why a failed extraction of one table causes the rest of the queued extractions to fail. Do you have any insight on why that happens?
Hi, sure, it depends on the data extracted, if the rest of the queued table extract is dependent on the failed extract then the rest will also fail. This is like when the header table fails, so is its Line Item table.
HTH
  • Apr 3, 2023 3:34 PM UTC
HTH
Is there a method to view the dependencies on a given table? These tables in question do not execute a join on each other or anything.
Can you provide what data connection or system in question ?
  • Apr 3, 2023 6:10 PM UTC
We are using a JDBC connection to a DB2 database.
