Dear all, is there a way to include the selected filter criteria when exporting data to xlsx or CSV? Thank you and kind regards, Michaela
  • Mar 15, 2023 1:02 PM UTC
  • 101 views
michaela.gebha
Level 4
  • Mar 15, 2023 3:46 PM UTC
Hi Michaela,
Filter criteria conditions do not get exported with the 'export data' function in an analyses, but you can use 'Export documentation' by HTML in the analyses - at the bottom of that exported documentation file is a section called 'Selections' which does give you the filter criteria.
