Date value different between excel and data model
  • Jul 18, 2024 11:35 PM UTC
  • 101 views
chi.wing.liu
Level 2
Hi all,
I am new to Celonis and I am trying to upload the data model using excel / csv, however the time value looks different when i upload it to Celonis. Would you please help to see how can i show exactly the same time on Celonis? Thanks in advance!
Time value in Excel
imageCelonis
Forum|alt.badge.img+7
I am assuming that you are using the Upload File in the Data Conncetion. Then right after uploading the file from your computer you can press the three dots on the right and select the option Configure Data Scheme, before starting the import. There you can set the format and data type in which you want to upload each column. The date might be wrong because it is displayed in another time zone but it should be correct when you upload it.
Please let me know if this helped. Configure Data Scheme on the bottom right
