Data Migration from one env to another
  • Mar 10, 2024 6:57 PM UTC
  • 135 views
I want to migrate data along with Data pool/ Analysis/Views, from one env to another. Is that possible? I migrated the data pool, analysis and other items, but migrating the data , I am not sure. Can you please help me on this?
  • Mar 11, 2024 4:16 AM UTC
Hi Sachin,
No, as far as I know, we cannot migrate the data from one environment to the other with the click of a button.
One workable way I can think of is to use pycelonis to retrieve the data from the source environment and upload it to the destination environment.
  • Level 4
  • Mar 11, 2024 6:55 AM UTC
great. Can you please elaborate or let me know how can I to do that and appreciate if you direct me where to get the code and details for that.
dennis.pflug
Hi Sachin,
here you can find more information and examples about pycelonis: Data Export - PyCelonis
I am not sure if you can directly get table out of a data pool and extract it into a data frame or if you need to do this via data models + export_data_frame.
Good luck.
BR
Dennis
