Cumulative Sum Question
  • Feb 27, 2026 6:51 AM UTC
  • 297 views
Forum|alt.badge.img+2
I want to calculate cumulative sum for column ‘Net Weight’ by Year . Below picture is result i want to have.
Column definition:
  1. ‘SO Created Year’ = ROUND_YEAR("VBAK"."ERDAT")
  2. ‘Created Month’ = ROUND_MONTH("VBAK"."ERDAT")
  3. ‘Net Weight’ =  KPI(“so_netweight”)
  1. Cumulative Sum=
         if I use formula : RUNNING_SUM(kpi("so_netweight"),order by("vbak"."so_creatd_year"), partition by("vbak"."created_month_so_"))  , i got below error.
can anyone help ?
Best answer by fabian.wende
thanks ​@fabian.wende .
But it does not group by ‘Created Month (SO)’ . It still give me the detail list. can help you ?
Yes I can help - I forgot to mention that you have to Aggregate the running_sum again:
This should be working fine:
SUM(RUNNING_SUM(*****))
fabian.wende
Level 6
You can’t use RUNNING_SUM on an SUM aggregate which then should be grouped in another way. Just use your RUNNING_SUM this way:
RUNNING_SUM(
"VBAK"."NETWR",
order by("vbak"."created_month_so_"),
partition by("vbak"."so_creatd_year")
(Additionally you switched order by and partition by, which I fixed)
Fabian
  • Level 10
  • Mar 5, 2026 1:12 AM UTC
fabian.wende
Level 6
  • Level 6
  • Answer
  • Mar 5, 2026 10:15 AM UTC
