Cropping the Process Explorer using a component filter
  • Nov 13, 2023 8:14 PM UTC
  • 255 views
The Process Explorer can have its activities cropped via use of the Crop Selection page filter, however when using the formulas CALC_CROP and CALC_CROP_TO_NULL in its component filter, the Process Explorer fails to crop
Can the Process Explorer be cropped via component filter? If yes, what is the correct formula / way to do this?
emiel.van.n14
Level 4
Forum|alt.badge.img+14
Hi Josh,
I would suggest to use Filters (on component level if using process explorer as a component otherwise on sheet or analysis level).
perhaps these links can be of help >> Link 1 and Link 2
  • Nov 15, 2023 7:17 PM UTC
Hi Emiel,
Thanks! Used the following formula as a custom dimension in the process explorer:
CALC_CROP_TO_NULL ( FIRST_OCCURRENCE ['Activity1' ] TO LAST_OCCURRENCE ['Activity2] , "Activity Table"."Column Activity")
Then converted it to a variable (i.e., <%=variable%>) so it could be used within a button dropdown where the Set Variable is chosen as a Button action, that way depending on the button dropdown selection, the formula updates with different activities to crop the process explorer in a different way.
Regards,
Josh
magdalena.silak11
Level 3
Hi Josh,
were you able to do it as a component filter? I am currently facing this issue.
BR,
Magda
Poovarasan
Level 1
  • Level 1
  • Apr 2, 2025 6:27 AM UTC
Hi Josh,
I am also trying to Apply a Component Filter to the Process Explorer, so that it can only show specific activities. I have already tried with several formulas but nothing seems to be working. can you share me any pql statement which i could use for this case.
Thank you
