Creating Use-case for automatic assignment of case.
  • Jul 5, 2022 1:31 PM UTC
  • 128 views
We want to create a use case where we have to assign a case to user depending on some criteria automatically in Celonis views/ analysis,
  • Jul 5, 2022 2:55 PM UTC
Hi @1460069472 ,
Can you be more specific on what your doubts and questions are?
  • Jul 5, 2022 4:52 PM UTC
More specificity would be good. This sounds like an action flow task. There are action flow examples in try celonis demos.
  • Jul 6, 2022 4:25 AM UTC
We are creating a view/olap where current owner of case is being showed, but current ownership of case is not available in backend data. I came up with a view where business user can assign case to user manually in column owner against each case. As shown in following image:
But Now, customer is asking us for automatic assignment of case to user where there will be a logic behind assignment will be the user with less no. of cases with him will be assigned to newly added case. Is there any example referring which I can achieve this requirement. Thanks for help in advance.
  • Jul 6, 2022 5:28 AM UTC
I'm quite certain an Action Flow is your solution. Check them out on TryCelonis demos. The Procurement demo has them for certain but other likely have them as well.
