Create view or analysis from data job logs
  • Mar 22, 2023 9:44 AM UTC
  • 101 views
sarina.somme
Level 5
Forum|alt.badge.img+11
Hello all,
is it possible to visualize the data job logs in an analysis or view in the studio? My customer would like to have an overview that shows how often the job failed or was canceled. Can I get this information from the Data Job Logs into the Knowledge Model?
Sarina
Forum|alt.badge.img+28
Hi @sarina.somme,
You can enable this by going to the Data Pools overview, and press the button in the upper right corner (see screenshot below). Now you will see a button 'Enable Custom Monitoring', which creates a new data pool where all executions are stored.
In the Celonis Marketplace, templates can be found of Studio Analyses to monitor the health of you pipeline via this link: https://{your-team}.celonis.cloud/store/ui/execution-apps/5ba85e94-f3e2-4679-9695-cc466e66f223 (or search for 'Celonis')
Custom Monitoring
