Create View Backend
  • Apr 19, 2024 10:17 AM UTC
  • 7 replies
  • 160 views
Hello guys, can you help me with this error message below? It started out of nowhere, I didn't touch this job and it started to show errors in it. I've never seen this type of error, have you ever experienced this?
dennis.pflug
Hi Douglas,
we use the same logic so far with no issues.
Have you tried to make use of UNSEGMENTED ALL NODES as described here:
https://docs.celonis.com/en/sql-troubleshooting.html#UUID-c15ca78f-b40c-735a-3ce0-2d74e9609b92_section-idm45897328432592342416797104
BR
Dennis
  • Apr 19, 2024 2:46 PM UTC
Hello Dennis, I tried to do it this way, I don't know if it's correct, because it still shows an error
CREATE VIEW "BKPF_UNION" AS (
  SELECT * FROM "BKPF_BSAK"
  UNION ALL
  SELECT * FROM "BKPF_BSIK"
DROP TABLE IF EXISTS "BKPF" CASCADE;
CREATE TABLE "BKPF" AS (
  SELECT
    ROW_NUMBER() OVER(PARTITION BY "MANDT", "BUKRS", "BELNR", "GJAHR"
          ORDER BY "MANDT", "BUKRS", "BELNR", "GJAHR", "_CELONIS_CHANGE_DATE" DESC) AS NUM,
    "BKPF".*
  FROM
    "BKPF_UNION" AS BKPF
) UNSEGMENTED ALL NODES;
DELETE FROM "BKPF" WHERE NUM > 1;
ALTER TABLE "BKPF" DROP COLUMN NUM;
DROP VIEW IF EXISTS "BKPF_UNION" CASCADE;
error : Execution error: ROLLBACK: DROP failed due to dependencies Detail: Projection "5cd18efc-518d-45db-a460-69694e102092_52bc3424-cada-4219-82cc-dadc6db9d1cc".BKPF_super has column NUM as part of its segmentation expression
dennis.pflug
Hi douglas,
have you tried to execute the queries one by one.
During which step exactly the error message comes up?
BR
Dennis
  • Apr 19, 2024 3:43 PM UTC
oops sorry I forgot to mention, I ran it line by line and the error shows this:Execution error:
dennis.pflug
Please try it with adding CASCADE also to your ALTER TABLE statement:
ALTER TABLE "BKPF" DROP COLUMN NUM CASCADE;
See: Dropping Table Columns (vertica.com)
If that is not working please try to change order of:
"BKPF".*
So that it looks like:
 SELECT
  "BKPF".*
  ,ROW_NUMBER() OVER(PARTITION BY "MANDT", "BUKRS", "BELNR", "GJAHR"
 FROM
That is just an idea as I read that Vertica will use the first 8 columns for creation of its super projection.
BR
Dennis
  • Apr 19, 2024 4:14 PM UTC
INCREDIBLE !!! Dennis, thank you again very much. I'm learning a lot from you. Your second suggestion worked.
Have a nice day !
dennis.pflug
Great to hear :)
Have a nice weekend.
BR
Dennis
