Create a Button to Navigate between Tabs
  • Jan 27, 2026 10:51 AM UTC
  • 272 views
Omar Abdelgelil
Level 2
Hello Community,
I am working in Celonis Studio- Views Asset where in one of the tabs i am adding a button that i want to use for navigating between Tabs.
I tried the “Open linked View” option and yet it doesn’t seem to save and nothing happens when testing it. Any Advice please ?
Thanks
manuel.wetze
Forum|alt.badge.img+9
Open linked View is intended for a seperate View which you would have to select from the dropdown, you can’t use it to open another tab of the same view.
But I would question why you need that anyway. Can’t the user just click the other tab itself?
If any help: I believe with a KPI list component you can switch tabs by clicking the kpi.
fabian.wende
Level 6
Just use the “Go to view or URL”-Function of the Button, and use the URL you got, when you open your View and have that tab selected, you want to navigate to.
Celonis saves the selected tab in the URL like this: /edit?activeTabs=XYZ
