Copying within a package
  • Mar 11, 2026 4:13 PM UTC
  • 277 views
Nick.Monteleone
Level 5
Is there a way to copy an existing asset to a blank tab on another asset within the same package?
Context: Separate assets were created vs tabs but want to combine into the same asset so the filtering is carried out through all tabs.
Will I have to recreate the “separate” assets within the new tab?
Are you trying to copy components between two tabs, or what kind of assets are we talking about?
For components you should just be able to copy paste using CTRL+C → CTRL+V
abhishek.chatu14
fabian.wende
Level 6
I assume you want to change multiple views to a single view with multiple tabs - in this case the answer above is absolutely valid - just select all components on your view by clicking and dragging to select multiple components, copy them and paste them in the new view on an empty tab.
