Connection issues with Standard SAP Connector
  • Feb 2, 2023 3:39 AM UTC
  • 124 views
I could able to successfully establish connection between SAP ECC and Celonis EMS standalone and the test extraction works fine. Now when I try to install standard SAP O2C connector with this connection, I get the below error. I dont get this error if I test the connection defined outside the connector. Request your inputs.
Best answer by teuku.faruq13
Hello @deepti.gandh , you need to change / adjust the standard connector to follow your SAP system. The error because your current setup is pointing to DBSAPSRV.sap.roots.com.
Also bear in mind sometimes the default connection has bug where you cant associate with uplink. In such case you have to create new connection, change / repoint data jobs connection to the correct one.
Hope help, let me know if you have further issue.
teuku.faruq13
Level 9
  • Feb 2, 2023 5:25 AM UTC
@Teuku Faruq
Thanks for the quick response. You are awesome.. It worked.. :).
