Coloring of KPIS / Columns in tables via YAML
  • Apr 16, 2024 8:33 AM UTC
  • 5 replies
  • 305 views
julia.bauer
Level 9
Hello everyone,
I'm currently working on a dashboard within a view.
There are two points where I'm probably lacking the YAML syntax or perhaps the "functionality" is not available yet:
1) Example without data - KPI - I want to color the number (in %) in e.g. red - is this possible?image2) I want to color the background of a column within an OLAP table - how is this possible in YAML?
Thank you for your support!
Best regards
Julia Bauer
Best answer by Sverre Klein
Hi @julia.bauer,
The comparator must not be part of the style attribute, it should be part of customAttributes key.
image.pngRemember that the comparator "IS_NOT_EMPTY" does not require a value to be compared with. Let me know if this works for you!
Sverre Klein
Sverre Klein
Forum|alt.badge.img+13
Hi @julia.bauer,
This is possible through custom objects and custom attributes. You can create display rules with them.
https://docs.celonis.com/en/knowledge-model---custom-objects-and-custom-attributes.html
It would look something like this:
customObjects:
 - id: DISPLAY_RULE_1
   displayName: Display rule 1
   customAttributes:
     - comparator: IS_EMPTY
        style: #styles to change the cell's appearance
         textColor: red
         fontSize: 16px
         fontItalic: false
         fontWeight: bold
You can then put the display rule in your YAML for the KPI.
- id: attribute
type: attribute
settings:
data:
- id: INVOICE.TOTAL_NUMBER_OF_INVOICES
displayContentRule: DISPLAY_RULE
You would do the same for the background color of column in an OLAP table, but then you would set in your display Rule the backgroundColor key under "style"
Let me know if you need help with this!
Sverre Klein
julia.bauer
Level 9
  • Level 9
  • Apr 17, 2024 11:20 AM UTC
Hi @julia.bauer,
customObjects:
   customAttributes:
         textColor: red
         fontSize: 16px
         fontItalic: false
         fontWeight: bold
- id: attribute
type: attribute
settings:
data:
Sverre Klein
Hello Sverre,
thanks for your help!
This is how I incorporated the display rule in the YAML KM View:
    internalNote: essential
    customAttributes:
      - style:
          label: true
          fontSize: 16px
          textColor: "#E8001F"
          comparator: IS_NOT_EMPTY
          fontitalic: false
          fontweight: bold
When trying to add the display to the KPI in the view (after publishing the KM) it does not work - the coloring does not change.
I've tried this with multiple display rules and it's always the same issue.
Could you fathom what the cause of this is?
Thank you!
Best regards
Julia Bauer
Sverre Klein
  • Level 10
  • Answer
  • Apr 17, 2024 12:56 PM UTC
Hi @julia.bauer,
Sverre Klein
julia.bauer
Level 9
  • Level 9
  • Apr 17, 2024 2:32 PM UTC
Hi @julia.bauer,
Sverre Klein
Hello @sverre.klein11,
thank you so much - I totally oversaw this. Now it is working!
Julia Bauer
Sverre Klein
Julia Bauer
You're welcome! 😊
