Chart with agglomerated dimensions from 4 different columns with the same options as values
  • Nov 22, 2023 7:49 AM UTC
  • 81 views
Hello everyone,
Is there a function or possibility to combine four different columns with the same possible contents into a single dimension? These columns are dependent on other columns and only if the value in column A = X I want to read the value from column A2, otherwise not. I have inserted an example.
Thank you very much!
For example: Here i would like to build a column chart where the dimension is X (coming from A-D) and the KPI is a sum from column A2-D4 where a X was in A-B (everhting marked red)
  • Level 0
  • Nov 28, 2023 11:21 AM UTC
Dear Jurgen,
Thank you for reaching out to us.
To be able to assist you further, we would suggest sending an email to servicedesk@celonis.com with a detailed description.
We will gladly try to help you.
We are always here to help and look forward to hearing from you.
Thank you in advance.
Regards,
