Change the initial module of an action flow without delete/create it
  • Nov 12, 2025 11:35 AM UTC
  • 137 views
Hi Community,
Editing an action flow, I want make a different module the initial one, without deleting the current one. Is it possible?
Regards, Repsol Support Team
Update: I coud do it exporting the blueprint from both the origin and the destination, copying with a text editor the module from one to another, pasting it in first position (being careful that the id is not repeated) and then importing the new blueprint.
Any way to do it with the GUI?
