Celonis Task Mining and Automation
  • Feb 2, 2023 6:10 AM UTC
  • 78 views
Is there a way to automate the tasks captured by Celonis Task mining?
I have captured desktop data/user actions for a task using Celonis Task Mining and data are loaded into EMS. After that, does Celonis provide any feature to automate (API or UI etc) those actions/tasks and run on any machine? Or need to use any RPA tool only for this automation?
abhishek.chatu14
Short answer is you need to use a RPA tool, some simple automations can be done through action flows feature in Celonis.
Celonis does provide exports of process definition documents, from an RPA (Robotic Process Automation) perspective, the Process Definition Document (PDD) in Celonis can be used to automate the tasks and processes captured through Celonis Task Mining. The PDD provides a detailed representation of the process flow, process map, process statistics, and task details. This information can be used to understand the process and identify areas for improvement, as well as to automate tasks using RPA tools.
