Capture duration between two process checkpoints and categorise if over a certain threshold
  • Dec 2, 2022 3:27 PM UTC
  • 133 views
jack.evera
Level 3
For late payments, we want to calculate or capture the duration an invoice takes between two process checkpoints and if it's over an expected duration, then we tag the entry with a reason label.
Example
If the duration between Vendor Creates Invoice + Scan FI Document is greater than 2 days
Then, add reason 'Late Submission / Missed in Inbox' into reason column
We have multiple statements to add for other checkpoints but the logic is the same.
Any help would be greatly appreciated
Thanks
abhishek.chatu14
Hi Jack,
Your reason column will look something like this
CASE WHEN CALC_THROUGHPUT ( FIRST_OCCURRENCE [ 'Submit draft' ] TO FIRST_OCCURRENCE [ 'Receive feedback for draft' ] , REMAP_TIMESTAMPS ( "Activity"."Event Time" , DAYS ) ) = 2
THEN 'Late Submission / Missed in Inbox'
WHEN CALC_THROUGHPUT ( FIRST_OCCURRENCE [ 'Acivity1' ] TO FIRST_OCCURRENCE [ 'Activity2' ] , REMAP_TIMESTAMPS ( "Activity"."Event Time" , DAYS ) ) = 2
WHEN ........ (this is where you put the next condition )
You can also replace FIRST_OCCURRENCE to LAST_OCCURRENCE based on your requirement.
Hope this helps !
jack.evera
Level 3
  • Level 3
  • Dec 2, 2022 4:07 PM UTC
Thanks for the quick response and detailed explanation Abhishek. We will take a look 😀
