Cannot Connect to Data Model on ML workbench
  • Aug 2, 2022 11:14 AM UTC
  • 207 views
Best answer by Anonymous
Hmmmm....
it should be really simple
celonis = get_celonis()
celonis.datamodels
(you will get a list of ALL the data models that your key has access)
datamodel=celonis.datamodels.find('datamodelname')
and data model is a data model object that you can use as per
https://celonis.github.io/pycelonis/1.7.1/reference/celonis_api/event_collection/data_model/
Most of the times can be that, simply, your key has not permissions.
Or that the name you put in the .find() is incorrect/misstyped/etc..... so .find() will return an empty value.
HTH
  • Aug 2, 2022 11:30 AM UTC
I am trying to make a connection to a data model through workbench, so far I have extracted the json file from the data pool and used both the data model id and the data model name in ;
pool = celonis.datamodels.find("--data model id--")
But so far I am getting no results found. Is there a process that I have to follow beforehand ? I am currently following the root cause analysis ipynb notebook
  • Answer
  • Aug 2, 2022 3:07 PM UTC
Hmmmm....
celonis.datamodels
HTH
  • Aug 3, 2022 8:41 AM UTC
It was actually a permissions issue, individual permissions do not "count" in workbench and was classified as another "user". Thank you very much !
