can you please help me to make a connecting in data pool
  • Jun 16, 2022 11:44 AM UTC
  • 148 views
Forum|alt.badge.img+28
Hi @1461004592,
Unfortunately I cannot help with 1-to-1 cases, since I'm not a Celonis Employee. However, please describe your problem clearly and let's see if I and the fellow Celopeers can help you!
  • Jun 17, 2022 9:25 AM UTC
Hi Mohsin ,
Please elaborate the issue you are facing.
I assume you are trying to connect using uplink connector to an On-Prem system.
Please confirm you have the following ready:
-- Infrastructure are per requirements
-- The extractor server you are setting up - runs on which OS ?
-- Have you downloaded the agent to server ?
Let me know which stage you are currently in ?
Regards
Ayan
