Can you create a process flow using the BOT logs
  • Jan 13, 2022 6:58 AM UTC
  • 29 views
If I upload the BOT logs, will it give me a logical process map/flow
Hello, simple answer is no (without additional work), however it may depend on the log structure.
Could you provide us with the log sample? If you will have those logs in table, you can try to create activities in SQL, f.e. if log contains words "Job ended" you can create activity that for each log with such message you will create activity in eventlog. that aproach moy work if the robot has good log data, and you have assigment of those logs to event time (date + time) and to specific bot / transaction. After creation of those activitiy transformations that will fill the eventlog you will be able to see process map/flow of the robot or the process.
Of course it will depend on how you created the activities.
