Can we combine processes from different source system type using Execution Graph ?
  • Oct 10, 2022 9:39 AM UTC
  • 169 views
Hello Experts ,
Is it possible to combine Business process from different source system type like SAP CRM or Salesforce CRM with SAP S4Hana Processes using Execution Graph and is it possible to design analysis to view interconnected processes (Quote to Order) using Multi-Event Log. Thanks in Advance
Regards,
Navalan Veerapandian
Best answer by Anonymous
Thanks for your Reply Guillermo Gost , Can this Use case then be achieved using Views in Celonis Studio ?
In theory, yes... just remember that "the devil is always in the details"... :P
Check here - https://docs.celonis.com/en/process-explorer.html
  • Oct 10, 2022 11:09 AM UTC
With multieventlog you can mix several activities and case tables. And they can come from several source systems. So... yes...
BUT
  • if using multieventlog in Analysis you try to show a very high level process, or a very complex one, it tends to generate a "spaghetti" view with a lot of variants. There are some tricks to alleviate that
  • if you want this kind of view you need Views, you can't in Analysis image
HTH
  • Oct 10, 2022 11:13 AM UTC
BUT
HTH
  • Answer
  • Oct 10, 2022 11:19 AM UTC
