Can somebody point me to the PSQL reference document?
  • Apr 8, 2022 8:21 AM UTC
  • 34 views
  • Level 5
  • Apr 11, 2022 1:49 PM UTC
Hi Srikant,
You can find all PQL related info from the help section. Try clicking on the help icon (screenshot attached) on the bottom left of the screen and type PQL. You will get a host of reference articles and documents (screenshot attached). That will help you..
Cheers,
JayB
