Can some help me on steps on how to create user defined models in Celonis?
  • Apr 8, 2022 5:30 AM UTC
  • 81 views
I need to create database/model and then insert data into the tables.
I tried to under below options , but it is getting stuck ( attached screenshot)
Data --> Data Pools --> Process Data Models
Forum|alt.badge.img+27
Hi @1460016855,
You cannot create a database in Celonis. You should upload a file instead or connect to a source database/application to extract tables. For every connection, a new schema is created automatically.
Once you have the tables in Celonis, you can connect them in a data model.
For more information on how to insert data in Celonis, you could follow the training track 'Get Data into the EMS (celonis.com)'.
  • Level 1
  • Apr 12, 2022 10:00 AM UTC
Thank You @janpeter.van.d  for your response.
When I am trying to create new data pool. The page is getting stuck and doesn't go ahead.
Are you also facing the same issue?
imageRegards
Arpit Gupta
imageRegards
Arpit Gupta
Hi @1460016855,
This page seems to be working for me:
datapool
