Can I upload SAP P2P files without using Quickstarts?
  • Oct 27, 2023 2:09 AM UTC
  • 145 views
스크린샷 2023-10-27 110314Currently, we have extracted files by SAP table as follows and uploaded them.
imageIt then asked me to select a table to use, which I did as follows
imageHowever, I'm stuck on the part where I specify the activity table.
When I uploaded using quickstarts, celonisEMS automatically created a table called "_CEL_P2P_ACTIVITIES", but I don't know how to solve it when I proceed with a normal upload.
If you know of a workaround for this, please let us know!
Thank you!
abhishek.chatu14
Don't you have to upload a event log i.e. activity table ?
The step that you are missing here is transformation, you will need to create the activity table by using standard transformations made by Celonis. I am not fully aware how QuickStart works for P2P but if you were not uploading any event log there then the transformation occurred there. Check the following to
understand how to create event log in Celonis
Transformations (celonis.com)
Transform Data - Tables for your Data Model | Partner (celonis.com)
  • Oct 30, 2023 12:13 AM UTC
thank you! I'll try it with the information you provided :D
