Can I filter on aggregated data in use cases?
  • Mar 7, 2023 9:23 PM UTC
  • 180 views
Hello, I am building a use case and I need to calculate several variables and show aggregared data in a form of 'SUM' vaue.
I do have a lot of data for the dimension I am using and I would like to limit those according to the 'SUM" value.
Is there any way that I could place aggegated filter?
E.g. SUM(A+B)>5
I am not able able to use the Pull-Up function here.
I would not prefer to Limit the rows or use First K Rows.
Ideally I am looking for an Option which would work in similar way as "Having" works in SQL.
Will be grateful for any answers/ hints.
Krzysztof
subhayu.monda12
Level 4
Forum|alt.badge.img+17
You could set the individual sums i.e. A and B as KPI's in your saved formulas. As long as they are being saved as KPI's they can be re-used anywhere else, even as filters.
Your filter would be something like this
FILTER SUM( KPI("A") + KPI("B")) > 5
Forum|alt.badge.img+14
Hi, have you tried the PU with domain table ?
FILTER PU_SUM(DOMAIN_TABLE("casetable"".casekey"), case.value) > 5
Hi Mondal, Filter statement should not contain Standard Aggregation, regardless of the input this statement throws an error.
  • Mar 8, 2023 12:04 PM UTC
Above comments should work if you want to sum over the different events in a case.
If you want to filter based on event records instead of case aggregations a simple statement like:
FILTER (A + B > 5); should work
From your context, it is not entirely clear what the issue is
