Can I create a pdf report using Action Flow there should be views dashboard should be pass as input.
  • Jun 13, 2024 9:24 AM UTC
  • 5 replies
  • 225 views
kandi.naidu
Level 7
Thanks,
Kandi Ajith Naidu.
Forum|alt.badge.img+7
Hello Kandi,
Indeed, it is possible to create a PDF report using Action Flows from data in the EMS with this module: image.png
Here you can find the detailed instructions on how to set this up.
Paulina
kandi.naidu
Level 7
  • Level 7
  • Jun 26, 2024 8:07 AM UTC
Hi @paulina.vázqu ,
Thanks for the quick response. Is filter is working in create pdf report ?.
Regards,
Kandi Naidu.
Hi Kandi,
Could you please rephrase your question? I'm not sure I understand what you are asking.
Paulina
kandi.naidu
Level 7
  • Level 7
  • Jul 3, 2024 8:32 AM UTC
Hi @paulina.vázqu ,
Sorry for the late response.
I am trying to fetch the new studio view which is created in analysis as pdf , when I encounter filters in the create pdf report in action flow , by using it i am unable to get the view which I want . Is it working same for you?.
Thanks,
Kandi Ajith Naidu.
Hi Kandi,
Did you try to use the <%=$CEL_ACTIVE_FILTERS%> function? Find more about the details here.
Paulina
