Can I apply a filter in individual components in views?
  • Aug 22, 2023 7:57 AM UTC
  • 226 views
tsholo.lesof
Level 2
Forum|alt.badge.img+12
  • Aug 22, 2023 8:04 AM UTC
  • Level 7
  • Aug 22, 2023 9:14 AM UTC
Hi @tsholo.lesof
yes we can apply the filter to individual components in views
option 1: You can define a filter in Knowledge model and later use it in views
go to code editor and add the pre defined filter
option 2: You can directly write your pql in code editor instead of - id you need to give the property - pql: Filter table.column = ‘value’
tsholo.lesof
Level 2
  • Level 2
  • Aug 22, 2023 10:07 AM UTC
tsholo.lesof
Level 2
  • Level 2
  • Aug 22, 2023 10:08 AM UTC
Hi @tsholo.lesof
Thank you, this helped!
