Can anyone help with the SAP tables required for Master Data Management process mining ?
  • Feb 28, 2022 4:58 PM UTC
  • 64 views
Hi Saravanan, Thank you for reaching out. You can find all the information for Connector Table Requirements at the following link https://docs.celonis.com/en/marketplace/table-requirements.html. Thank you for your patience and understanding. Best regards, Valmira Abdiu
