Calculate the amount of handover moments within a case and also calculate an average for all cases.
  • Nov 14, 2023 1:12 AM UTC
  • 178 views
emiel.van.n14
Level 4
Forum|alt.badge.img+14
Hi Community, I want to visualize the amount of handover moments within a case and also calculate an average for all cases. We have multiple tables but the most relevant are of course the case table (incl. Case_Key, Case_ID) and the activity table (activities, Case_Key, Case_ID, USER_ID). The USER_ID contains the relevant info I want to use for defining the handovers but I can't seem to pull it off. Any tips?
Best answer by emiel.van.n14
In the meantime I found the solution by simply using the PU_COUNT_DISTINCT PQL function. More information >> here
I used the first example
Column 1: "companyDetail"."companyCode"
Column 2: PU_COUNT_DISTINCT ( "companyDetail" , "caseTable"."value" )
To AVG the handovers across all cases I simply added AVG to the equation > "AVG(PU_COUNT_DISTINCT( "companyDetail" , "caseTable"."value" )
Works as expected.
mateusz.dudek14
Level 11
Forum|alt.badge.img+10
Hi Emiel,
Can you provide an info on what the system that you're taking data from? Usually for such purposes we're using tables that tracks changes in specific items f.e. in SAP environment those are tables called CDHDR and CDPOS (header / item for changes). If there's no specific, global table for such things, try to get a log for specific item - that should contain info that on date DD,MM.YYYY some user took over the case. Thank you need to clean it and generate as many activities for case as these changes with added information which user took it from which. That way you can start calculating KPI's mentioned in your post.
Best Regrads,
Mateusz Dudek
emiel.van.n14
Level 4
Hi Mateusz,
thanks for your quick reply.
The relevant data is already available in Celonis. We've a data model that contains an activity-tabel including Activities, Timestamps, USER_ID, etc. on Activity level so we know who is performing a certain activity. I'm 'just' looking for the PQL to calculate the amount of handovers. We know that activities go from USER_ID1, to USER_ID2, to USER_ID3 and back to USER_ID1 (or other variants). By doing so we want to know the number of colleagues involved in a case (avg across all cases, absolute on case-by-case, trends, etc.).
Off topic; we needed to anonymize the USER_IDs to avoid capturing personal data so we made a python script that anonomyzes and pseudonymizes on case level. The end result is (example): USER_ID 1 = Pseudo123ABC and USER_ID2 = Pseudo123ABC within Case_ID 456. The script went through the entire dataset and did this case by case. So another example: for Case_ID 987 USER_ID1 = Pseudo765XYZ and USER_ID2 = Pseudo345KLM, etc. By doing so we can still we can still identify handovers within a case (albeit anonymized but that's OK). At least that's the idea.
Hope this helps in getting some context behind the question.
emiel.van.n14
Level 4
  • Level 4
  • Answer
  • Nov 14, 2023 9:08 PM UTC
Works as expected.
