Calculate Ratios
  • Aug 4, 2022 12:21 PM UTC
  • 157 views
Hi, I have a table with numbers and ratios in it. And I also have a dropdown list. I want to use the dropdown list to filter the table. And for ratios, I want those sum up to 100% even after filter. I tried to use variables in the component filter to do so, but it doesn't work. Any great ideas would be appreciate.
  • Aug 4, 2022 2:19 PM UTC
Something like this would work, for instance % of cases per dimension adding up to 100%.
Case count / GLOBAL (Case Count)
Forum|alt.badge.img+28
Hi @Yuyao Wang,
Not sure what your formula and situation is, but the formula 'FILTER_TO_NULL' is always fruitful if you want to apply filters on calculations. This function maps all field to NULL if they have a superior filter applied. If this is applied to both your denominator and divisor, it should bring the total to 100% again.
Hope this helps,
  • Aug 6, 2022 4:47 AM UTC
Hi @Yuyao Wang,
Hope this helps,
Hi, Jan-peter
Thank you so much. I have a table like below. My formula originally is 'SUM("table"."column") / <%=variable%>', I use static value as SUM("table"."column") for the variables. When I apply the filter with dropdown list, the static value apparently can't be filtered.
This table shows the sum up data of my whole table, what I want to do is that when I select one thing from dropdown list, this table shows the data for the specific thing I selected. And the percentage is recalculate as each data divided by the sum of the data. E.G. scope1/(scope1+scope2+scope3) for the one I selected with dropdown list.
Screenshot 2022-08-06 at 13.43.56
  • Aug 6, 2022 4:48 AM UTC
Hi, Pim
This table shows the sum up data of my whole table, what I want to do is that when I select one thing from dropdown list, this table shows the data for the specific thing I selected. And the percentage is recalculate as each data divided by the sum of the data. E.G. scope1/(scope1+scope2+scope3) for the one I selected with dropdown list.Screenshot 2022-08-06 at 13.43.56
