C4C collaboration models vs EMS Implementation
  • Jul 24, 2023 2:17 PM UTC
  • 72 views
Forum|alt.badge.img+7
Hello, I am trying to frame the difference between Celonis for Consulting collaboration models and the EMS implementation.
It is correct to say that with the C4C I will be able only to perform the discover collaboration way, while I would need the Partner Enablement Program Certification to deliver also in the execute and in the operate collaboration model?
Furthermore, wich is the concrete difference between execute and operate? Can you provide some practical examples?
  • Jul 24, 2023 2:50 PM UTC
Chiara: do you have access to the partner portal? There in the asset library you have extensive information. For example in the "Intro to C4C relaunch" it explains the different "flavours" of C4C
I suggest you speak with your Celonis contact to maybe get some of those documents.
HTH
