By setting up an Action Flow to create and send a CSV, I don't want to display the timestamp within the CSV. The "formatDate" function does not work. Does anyone know, why this is happening?
  • Mar 13, 2024 10:43 AM UTC
  • 8 replies
  • 203 views
julia.oppen11
Level 6
julia.bauer
Level 9
  • Level 9
  • Mar 13, 2024 1:39 PM UTC
Hey Julia,
I would add this formula to your query module beforehand: LEFT(TABLE.COLUMN, 10) and then only use the formatDate(Confirmed for; DD.MM.YYYY) in the CSV module.
Hope this solves your issue.
BR
Julia
julia.oppen11
Level 6
Hi Juilia,
thank you for your answer. When trying this, I get the following ERROR massage:
BR
Julia
Sverre Klein
Forum|alt.badge.img+13
Hi @julia.oppen11,
To extend on @julia.bauer's solution, the LEFT operator only works with columns of type STRING. In that sense, you must first cast the datetime column to string using TO_STRING.
Here is some documentation TO_STRING (celonis.com)
Hope this will help you!
Sverre Klein
julia.oppen11
Level 6
Hi Sverre,
the problem is, that I need the type Timestamp, as the date I will show in the CSV in the end, need to be the ROUND_MONTH and this is not possible with the type String.
BR,
Julia
matt.witty13
Within the Create CSV module, what is the data type you're sending?
imageIf you're sending this as a date, Excel will read the timestamp in. If you send as text, it'll send in whatever format you put together.
I'd also recommend putting together a "Set Variable"/"Set Multiple Variables" module before the CSV setting the date format and then passing the formatted date into the CSV. I've found it runs smoother that way.
julia.oppen11
Level 6
Hi Matt,
I do not have the possibility to select a TYpe within the CSV module:
imageI will try to add the "Set Variable"/"Set Multiple Variables" module, but I don't know whether it solves my problem.
dennis.pflug
@julia.oppen11 : You can see and change the data type within the Data Structure "SWF_Delivery Reliability by clicking on the three dots ans select "Edit".
matt.witty13
Hi Matt,
Okay where it says Data Structure, click the 3 dots.
You should see 'Edit' and 'Clone'. Click Edit.
Edit should bring you to the screen of the format of the different columns.
