Business hours calculation
  • Jan 25, 2022 12:40 PM UTC
  • 6 replies
  • 117 views
Is there a way to calculate all KPIs by considering working days only? e.g. 5 workdays per week? e.g. average case duration would be lesser considering 5 days instead of 7.
I'm affraid that you cannot change the default KPI's. However can create a new ones, and combine WEEKDAY_CALENDAR with CASE WHEN and REMAP_TIMESTAMPS. Sample:
Calculate the number of working days between two dates using the REMAP_TIMESTAMPS function. It is assumed that working days are from Monday to Friday (with 24h a day).
REMAP_TIMESTAMPS (
   "TimestampTable"."DateColumn2" ,
   DAYS ,
   WEEKDAY_CALENDAR ( MONDAY TUESDAY WEDNESDAY THURSDAY FRIDAY )
REMAP_TIMESTAMPS (
   "TimestampTable"."DateColumn1" ,
   DAYS ,
Mateusz Dudek
  • Level 3
  • Feb 2, 2022 2:23 PM UTC
REMAP_TIMESTAMPS (
   DAYS ,
REMAP_TIMESTAMPS (
   DAYS ,
Mateusz Dudek
Hi @deleted deleted
Thanks for your answer.
So if I want to calculate average throughput times considering 9-5 pm workdays, I'd have to use AVG(CALC_THROUGHPUT(FIRST_OCCURRENCE['Event1'] TO LAST_OCCURRENCE['Event2'], REMAP_TIMESTAMPS("eventlog"."TIME", DAYS,WEEKDAY_CALENDAR ( MONDAY TUESDAY WEDNESDAY THURSDAY FRIDAY 9:00-17:00))))
Is this correct?
Hi @deleted deleted
Is this correct?
@1460068767 Looks good to me, however it's hard to tel if the logic and syntax are correct without extensive testing - let me know if that worked :)
Please note that all events done in those days, but outside the working hours may not been considered as working day activities - however I'm not sure about that.
Mateusz Dudek
  • Level 3
  • Feb 4, 2022 5:07 AM UTC
Hi @deleted deleted
Is this correct?
Hi @deleted deleted
Seems like Celonis has this thing inbuilt. I found the Calendars option in the process data model section, where we can define a calendar. Thanks for your reply.
Hi @deleted deleted
Is this correct?
Hi @1460068767,
About that build-in calendar - i've tried to use it on on-prem version (4.6) as there's no weekday_calendar pql function. However it doesn't work, so it's hard to recommend it.
Have you solved your problem using that?
Mateusz Dudek
  • Level 3
  • Feb 21, 2022 8:15 AM UTC
Hi @deleted deleted
Is this correct?
Hi @deleted deleted
I am using the Celonis free plan on cloud, so not sure about on prem. But the calendars option did solve my problem.
