Benchmarking in Views: How to link KPI Lists and Process Explorers to the selected fields
  • May 4, 2023 11:57 AM UTC
  • 135 views
Hi. In views, when designing a benchmark tab, I want to link both the PE and KPI lists to the chosen dimension.
I select a dimension in a first dropdown (eg. Company Code) , then select the different company codes I'm trying to compare (in a different pair of dropdowns), but these components (Process Explorer, KPIs, etc..) do not update. In analysis I'd need to create a component filter, but how to proceed working on views?
badrinath.nooka13
Level 4
Forum|alt.badge.img+14
You need to add filter condition in the yaml editor of process explorer or kpi list of views to show only for selection in drop down.
for example:
filters:
  - pql: FILTER "${dd_variable ==
      'Company Code'?'case_table':dd_variable
      =='User'?'activity_table''}"."${dd_variable}"
      = '${process 1}'
here company code is coming from case table, user is coming form activity table so when they select company code in main dropdown it will be updated in dd_variable and values related to company code are shoun in drop down 1 and this selection is stored in process 1 variable and using this we filter components.
The above condition works lie a if else condition and it finally becomes something like FILTER 'case_table'.'Company code' = '00001'
Hope this is clear, any doubds please comment
