AWS connection from s3 to celonis. Where exactly is the window to enter the key and secret to achieve the connection (the documentation is a bit lacking)
  • Jun 21, 2022 11:06 AM UTC
  • 105 views
  • Jun 22, 2022 11:51 AM UTC
Hmmm... probably you have tested it ... For me it seems here is clear
https://docs.celonis.com/en/aws-s3.html
Once you have finished the setup in AWS, go to the AF, select the module AWS S3 (the function you want, I picked Get File) then press in Add to define the connection and you get another pop-up where to write the Key and Secret
But, you know, I haven't yet tested it in real-life end-to-end, so it is perfectly possible I am wrong.
  • Jun 22, 2022 11:58 AM UTC
Hi Gost,
It seems that the specific action is not possible unless there is access to the paid account (I was using the free plan).
  • Jun 22, 2022 12:02 PM UTC
Sorry, but at least you got the reason... you can't fix it, but you know why it doesn't work ... 😛
  • Jun 22, 2022 12:06 PM UTC
That is true 😅
