Automatic tailoring of PQL queries using Static PQL checks (2024-08-28)
  • Sep 5, 2024 12:37 PM UTC
  • 76 views
You can now write PQL queries that run based on the outcome of one or more data model conditions, such as the data type of a column or the existence of match list elements in comparison operators. Before your query is run, Static PQL dynamically checks some properties of your data model and modifies or cancels your PQL query depending on the outcome of these checks. This lets you define business applications that can be used with a range of different data models, helping drive standardization.
For more information, see Static PQL functions.
