Augmented Attributes used in Filters and KPI definitions inside a Knowledge Model.
  • Jun 23, 2023 9:06 AM UTC
  • 246 views
javier.desar
Level 4
I am using Augmented Attributes in a Knowledge Model to build a View App.
The A. Attribute is defined to have 4 possible values (dtype string) and it is meant to be updated manually by the end-user in the app to any of those 4 values.
It has a Default Value as well for all those cases where the end user did not manually updated the attribute (which happens frequently).
The problem comes when I want to use the "VALUE" field stored in the augmented table from the attribute in the Knowledge Model. I want to filter a chart based on the Attribute´s values (again stored in the VALUE field) and also define a KPI with a CASE WHEN logic based again in the value of the attribute.
When I do so, it just returns the rows or datapoints where the Attribute was manually updated, filtering out all the rows for which the default value should appear.
I have not found a way to include the default value in the PQL queries outputs that I desire, so that I do not get most rows filtered out when I use an Augmented Attribute.
Does anyone know how to tackle this issue?
Thank you very much!
Javier
Best answer by philipp.dehn
Hi Javier,
we currently have the same topic in one of our use cases.
I think this can be solved with using PU Functions. I explain what I mean:
The record we have is the order number AFKO.AUFNR .
For this we have defined an augmented attribute, with only possible value „X“. The default is empty.
When I now show the VALUE field of the augmented attribute in a table, it shows only the values, where the value „X“ was set by an user. All other orders are not displayed. It is also not possible for me to set a filter on the orders where the value is initial, e.g. via something like VALUE IS NULL.
But it works, when I put it into a PU function.
E.g. In the table you can do PU_FIRST(AFKO, …VALUE). Then all orders are shown, either with VALUE being „X“ or NULL if not set by a user.
Same for the filter, where we put FILTER PU_FIRST(AFKO, …VALUE) IS NULL, and it shows all orders, where the augmented attribute was not set by a user.
You may check, if this works for you as well.
Maybe there is also a better way, but this seems to work.
BR Philipp
philipp.dehn
Forum|alt.badge.img+2
  • Community MVP
  • Answer
  • Jul 2, 2023 11:21 AM UTC
Hi Javier,
BR Philipp
javier.desar
Level 4
  • Level 4
  • Jul 3, 2023 1:47 PM UTC
Hi Philipp,
thank you very much! that actually solved the problem :)
BR Javier
