Apply a filter on CALC_THORUGPHUT
  • Jan 27, 2022 1:30 PM UTC
  • 190 views
Hey,
I want to measure the lead time between two activities, but which must contain a certain (variable) attribute.
I tried this with the function "BIND_FILTERS" but fail. Does anyone have a solution for something like this?
MEDIAN (
  CALC_THROUGHPUT (
    FIRST_OCCURRENCE [ '<%= Step_1 %>' ]
    TO
    FIRST_OCCURRENCE [ '<%= Step_2 %>' ] ,
    REMAP_TIMESTAMPS ( "_CEL_SCHUTZBRIEF_ACTIVITIES"."EVENTTIME" , MINUTES )
  BIND_FILTERS ( "_CEL_cc_claim","ANS_KNZ_Mapping_csv"."ANS" = '<%= ANS_01 %>' )
Best answer by Anonymous
Hello Daniel,
It depends when and how you want to utilize this formula:
1) You can try use CASE WHEN in addition to CALC_THROUGPUT
2) Include FILTER Statement on analysis / component level
Bind filter statement should be used with mutliple filters used with "AND" statement.
Below sample code:
1) <aggregation>
CASE WHEN "_CEL_CASES"."DOCID" = 2859131 THEN
0
ELSE
CALC_THROUGHPUT (
    FIRST_OCCURRENCE [ 'A' ]
    TO
    FIRST_OCCURRENCE [ 'B' ] ,
    REMAP_TIMESTAMPS ( "_CEL_ACTIVITIES"."EVENTTIME" , MINUTES )
B) FILTER "_CEL_CASES"."DOCID" = 2859131
Hope it helps :)
Mateusz Dudek
  • Answer
  • Jan 27, 2022 2:28 PM UTC
Hello Daniel,
Below sample code:
1) <aggregation>
0
ELSE
CALC_THROUGHPUT (
    TO
Hope it helps :)
Mateusz Dudek
  • Feb 2, 2022 9:53 AM UTC
Thanx!
