APC Trend by Month
  • Nov 29, 2022 4:44 AM UTC
  • 151 views
Hello!
we are using the data monitoring dashboard to cleanup redundant tables and improve capacity. We want to show the APC trend by Month. Currently it sums up the APC per day and shows the total . is there a way to show this trend with accurate APC usage per month ?
abhishek.chatu14
Yes you can display the APC trend by Month, just change the created_at dimension to ROUND_MONTH( "tablename"."created_at"). Make sure to change the format to Year-Month, hope this helps.
  • Nov 29, 2022 2:25 PM UTC
the problem i am facing is the sum of size in bytes attribute adds the APC for each day and gives a huge number. how do i make it pick a value or provide an avg for a month which truly reflects the APC consumed.
abhishek.chatu14
Wouldn't max of the sum size solve your problem ?
Try using something like a moving max for this problem MOVING_MAX ( "Table1"."Column" , - 1 , 0 )
Lovise Hellner
sharing this a bit late, but could help some others
I am using the below formula, and then you can change the date format to month, year, quarter etc...
SUM("data_consumption_events"."size_in_bytes") / 1000.0 / COUNT(DISTINCT "data_consumption_events"."id")
