Allowlisting Celonis IP addresses
  • Mar 30, 2023 3:38 PM UTC
  • 139 views
Hi everyone,
I have a problem executing an HTTP request through the Action Flow. In fact, when I try to make a request, I get the status code 403 because, as the log says, the source IP is not in allow list. Furthermore, the client IP shown in the log's details is different every time.
Then, what outbound IP range should I have to communicate to the customer to solve this issue? In the Celonis' documentation I found these addresses (the second column is the one for the source IPs):
Allowlisting IP addresses
Could they be correct?
Thanks in advance,
Emanuele
Hi Emanuele, thank you for reaching out! To be able to help you more can you please reach out to us by creating a Support Ticket, to Celonis Customer Support as follows: Web: https://www.celopeers.com/s/ Best regards, Rrezarta
