alert on an input
  • Feb 28, 2024 8:06 PM UTC
  • 97 views
We want to make an alert within an inputbox that is related to an action (view) that leads to an increased attribute indicating that it has exceeded a maximum number of characters. Do you know how to achieve this?
  • Level 0
  • Mar 7, 2024 9:40 AM UTC
Hi Maicol,
so you have an inputbox and when the input exceeds a given number of characters you want to give a warning correct?
If the warning can happen right away in the view, I would suggest you write the input from the inputbox to a runtime variable and then have a KPI checking the length of that variable, giving appropriate warnings. You can then display the KPI right next to your input box:
  1. Create Runtime variable: Name = value_box_input, the value has to be one space
  2. Create KPI in your knowledge model: Name = Value Box Check, PQL = CASE WHEN len('${{input_box_value}}') > 10 THEN 'Input to large' ELSE 'Input Valid' END
  3. Create your input box with the following yaml:
type: input-box
settings:
  type: string
  value: ""
  onChange:
    update:
      variables:
        - name: input_box_value
placeholderText: Type your input
Then you can place your KPI in a KPI-List component right next to your input box and see the screenshot for how it would look like:imageLet me know if that helps or if you have a question about it.
Tim
