[Action Flow] Webhook Error when I duplicated a Action Flow.
  • Aug 10, 2022 12:47 AM UTC
  • 141 views
Hi. There is a webhook error when I duplicated an existing Action Flow.
I duplicated Action Flow A to B, then I added a new webhook to B and tried to save it, but the following exception occurred.
Am I doing something wrong?スクリーンショット 2022-08-10 094558
Best answer by tringa.rexhe
Dear Xingzhu, Thank you for reaching out. Could you please try to create a new Action Flow (without duplicating), add a new Webhook, and copy-paste the other modules? Currently we have an issue from our side, which we are working to fix but we do not have an estimated time. Many thanks and best regards, Tringa
  • Level 0
  • Answer
  • Aug 11, 2022 11:38 PM UTC
