Action Flow: Sharepoint Online XLSX Question
  • Dec 8, 2023 12:36 PM UTC
  • 312 views
I have the following problem: I would like to upload a .XLSX file into my workspace via an ActionFlow. The .XLSX file is located on SharePoint Online. I can download the file using the "Download a File" action (Microsoft SharePoint Online) in the ActionFlow. However, I'm stuck at that point. In the output, the data is in "binary" format. How do I convert it from binary back to something I can import into a workspace? I have tried many things, but I just can't find the solution. Does anyone have any advice?
Hi, I would suggest creating a support ticket by providing your environment details for further investigation.
magdalena.silak11
Level 3
Hi Michael.
Were you able to solve the issue? If you did could you leat me know what is the solution?
BR,
Magda
Forum|alt.badge.img+28
Hi @michael.lenz,
Did you try using the Excel Component for Action Flows? It seems it has more options to obtain data from an Excel file: https://docs.celonis.com/en/microsoft-365-excel--action-flow-.html.
I hope this helps!
Arnab17
Level 1
  • Level 1
  • Sep 10, 2025 9:26 AM UTC
hi,
Try converting binary code to text format using tostring function.
please refer to this link - String functions
